Saltar al contenido principal
La versión slim de la clásica Xbox 360 con un HDD de 250 GB y Wi–Fi integrado. Repararla requiere herramientas especiales.
Preguntas 236 Ver todo
What Is The RDOD? Can I Fix It Myself?
I have an Xbox 360 Slim, I've had it for 5 years and 4 months and have never had any problems with it what so ever. So...I turned it on the other day, I played on it for about 20 minutes then it just completely froze and there were a bunch of grey lines all over the screen, I turned it off, left it off for several minutes and turned it back on, after about 10 seconds that red dot in the middle of the power button turned to solid red and every time I turn it on it makes a strange noise like something is trying to start but something else is preventing it from doing so. Does anyone know what is causing this problem? (Could the problem be that I always leave my Xbox on a shelf? Or because there were some storm issues about 4 days ago and the power to the whole house kept going out?) My warranty expired about 2 years ago so is it worth paying for it to be fixed or should I just buy a new one?! Any advice will be appreciated!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
Kits de Reparación de Batería de MacBook Air
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
1 Respuesta
Solución Elegida
kloosdaniel, the only thing that I can come up with so far is the RDOD (Red Dot of Death)Since it is not under warrant, check the optical drive. Apparently it can cause the RDOD :-) Also check Youtube for some decent explanations. This video shows one more trick you can try. If none of that works, open your console and clean the airvents properly of all collected dust and debris, change the thermal paste and try, or consider a reflow. Hope this helps, good luck.
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
kloosdaniel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 20
Últimos 30 Días: 51
Todo El Tiempo: 2,538
