Saltar al contenido principal
Cen-Tech Seven Function Digital Multimeter . Model number 90899.
Preguntas 8 Ver todo
Why won't the screen show any readout?
I want to use my multimeter to test a battery. The banana plugs are attached and cords are attached to the device, but the screen is not reading anything. My device is turned on and seems to be functioning otherwise.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
2 Respuestas
The reading screen is either broken or malfunctioning. You may need to replace the screen. See screen replacement guide here. If this does not seem to fix the problem, you may have an issue with the motherboard. Click here to see how to replace the motherboard.
Imagen de Cen-Tech Seven Function Digital Multimeter Mainboard
Guía
Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
Dificultad:
Fácil
5 - 15 minutes
Imagen de Cen-Tech Seven Function Digital Multimeter Screen
Guía
Cen-Tech Seven Function Digital Multimeter Screen Replacement
Dificultad:
Fácil
10 - 15 minutes
Fue útil esta respuesta?
Puntuación 0
I'm all for fixing stuff and keeping it working, but Harbor Freight literally gives these meters away. They're not worth fixing. i have a stack of spare ones still in the package waiting to be used.
Puntuación 0
Añadir tu respuesta
Anna Kihm estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,667
