Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Repair guides and support for all types of batteries.
Preguntas 31 Ver todo
Risks of short-circuiting Li-ion battery?
I received a new Haier Li-ion battery (haier h11255) for my cell phone and although it seems identical to the old one, it does not work. After some tinkering I discovered that the 4 'pins' on the battery are in another order then they should be. I can easily fix this by connecting two of the pins, which I tried using a paperclip. Is there any risk doing this? If so, what are they?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Definitely get rid of that battery. One of the four pins is used to measure BTemp (battery temp.). When it's temp. is beyond a specified range, the battery will stop charging to prevent overheating. Unordered pins are a bad sign.
Fue útil esta respuesta?
Puntuación 0
Respuesta Más Útil
Return the battery and get the correct one. Don't chance it!
The battery can explode or catch on fire if sorted.
Puntuación 1
Añadir tu respuesta
Tom estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 487
