Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 3001 Ver todo
water damaged iPhone but only while connecting to power, still work
Hi guys
While skiing, I kept my iPhone4s in my trowser pocket. Certainly It was not good place but I did it, water droplets any how succeded to went inside phone and it was turned off. On same day whole night I put iPhone under table lamp to get it dryout. Again next day it was not turning on. Latter on, when I connected to power, all functions are working and after removal of power again switched off. Please suggest me what to do.
Thanx in advance...
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
Thnx for useful reply. I did the aforesaid above and my iphone is working now. The problem I am facing now is the short life time of battery. After full charging, my iphone battery life is around 4-5 hours only. Kindly suggest any useful way to enhance the battery life time.
Thnx in advance
por
You did get a new battery?
por
Yes, I put new battery
por
Agregar un comentario
Kits de Reparación de Batería de MacBook Air
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
1 Respuesta
Solución Elegida
ajay, the table lamp will not evaporate enough water. You will have ongoing corrosion damage. I suggest that you using the device, (remove the battery) and totally disassemble it. Then clean it with +90% isopropyl alcohol. This will displace the water and stop corrosion. It it okay to submerge a board in isopropyl alcohol. After that, air dry all the components. Do not forget to clean the connectors on the board as well as the cables. Then re-assemble with a new battery This is not optional but a must to avoid failure later on. " Check your board for any missing or damaged component. Water damage is the toughest to trouble shoot and to repair. Hope this helps, good luck.
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
ajay estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 77
