Saltar al contenido principal
Una videoconsola producida por Sony Computer Entertainment, también conocida como PS4. Anunciada el 20 de febrero de 2013 y lanzada el 15 de noviembre de 2013.
Preguntas 1690 Ver todo
Controller only works from 5 feet away or closer from ps4
My son pulled ps4 from shelf and it landed on its corner. Since then, it only recognizes the controller from close range. I was wondering if the optical pickup could be jarred from its proper place. Ive already tried resetting and rediscovering the controller with same result
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
4 Respuestas
Respuesta Más Útil
PS4's don't use optical pickup. The controller connects to the PS4 via bluetooth. This console has an integrated bluetooth/WiFi chip that controls both the WiFi and bluetooth capabilities.
I'm guessing when you dropped it you may have broken the WiFi antenna or caused the antenna cable to become unattached from the motherboard. It's also possible that the WiFi/Bluetooth chip broke when it was dropped, but that is not as likely.
If you need someone to take a look at it for you I would be happy to do that. Just click on the link by my name that says "TronicsFix" and that will take you to my business listing that will have a link to my website. There are also lots of other businesses listed on IFIXIT.
I hope this helps.
Fue útil esta respuesta?
Puntuación 4
The wifi antenna has two solder points. The one on the right frequently breaks loose especially if dropped. It needs soldered back on. It's seldom the antenna detaching from the board. All it takes is the antenna itself being bent a little to pop the solder joint loose.
Hope this gets everyone going again.
Puntuación 1
1 comentario:
Thanks kcxbox repair, you were so helpful, I just hope you are still alive after so many years to receive the many thanks 👍
- de
I have the same problem. But I didnt drop mine. I got bought it from gamestop new. Probably they did. But in order for me to operate the ps4, the controller must be in a very close range to the actual system . IV tried resseting the system and the controller but no help. Ive even tried multiple friend controllers, still no results.
Puntuación 0
1 comentario:
There is a good chance that they never tested whether the controller would work from a long way away. I would take it back ASAP. There aren't a lot of other things that would cause this. Either way I'd take it back.
- de
Yea, the same problem happens to me, I had dropped it and my controller has to be within a 3 foot range of my ps4 for it to work. I had also dropped it on the corner edge and it has been like that ever since
Puntuación 0
Añadir tu respuesta
Ron estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 22
Ultimos 30 días: 76
Todo El Tiempo: 17,677
