How can I get the radio tuner driver after upgrading to win7?
After upgrading to windows 7 the radio tuner driver is missing, Microsoft and HP have no solution. My unit is a m7680n HP Media center PC.
Es esta una buena pregunta?
If this is for the OEM TV Tuner, I would suggest pulling it out and buying some PCI slot blanks to fill the holes on the case in. The tuner in this system is analog only, so it is useless for TV. With that being said, the RCA and S-Video will continue to work.
If you plan on using this card for TV, let me crush your dreams and say that isn't happening due to the DTV switch. However, if you can get it working it can be used for RCA or S-Video. If this is the intention, I'd see what you can do if it makes economic sense.
You have 2 options:
It's really up to you. If you want to use it for TV, junk the card and buy a new one. However, if the intention is to use it as a capture card then it's worth trying if you can't afford a standalone card or want to try your luck before going external.
Fue útil esta respuesta?
NO the TV tuner works OK The Radio tuner is the one not working. But like you stated it is analog so bye bye radio. the TV tuner I use for copying videos from tape. Thanks for the info. Lee
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 299
