Get no video detected when pic is turned on
wont boot
Es esta una buena pregunta?
wont boot
Try to clean the RAM with an aluminium or an eraser.
Fue útil esta respuesta?
Make sure the red switch on the back of the power supply is switched to the correct side.
If it was switched to the wrong side, the power supply would be blown
Use a different Monitor, if this doesnt work. Replace the VGA card, if this is not the problem and your VGA is onboard, Enter the BIOS and disable it. Then add a VGA card.
This can be caused by a couple reasons. First When you turn on the PC, does it make any particular noise? If the PC is turning on normal I would try switching your display wire in order to make sure that its not simply the wire not sending the image to your monitor. If after you switch the wire you still don’t see an image try to to double check that your monitor is actually able to display an image., by turning the monitor off and than back on. If your able to see the start up screen of your monitor, than you might need to trouble shoot the display card in your desktop. First try this and than let me know if you still need more help.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,697
