Why can't my phone turn on?
I tried everything I can but the phone won't turn on, not even if I am changing it.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 21
Comentarios:
First time battery has run out. Won't switch on
por
Agregar un comentario
6 Respuestas
Respuesta Más Útil
You could try to change the battery since there is a high chance that it is juiced out. You also might want to do a check of the charging cable you are using, if it is working fine or not
Fue útil esta respuesta?
Calificación 2
It wont open for 2 months so i still cant use any phone right now im using my computer plz help maybe i because my cousin borrowed my adoptor t5hen i found a soccet that could fin in the charger mine maybe ruined the battery or what ....last week i tried to charge it then i wited bit to turn on then i chrage it into 100% thern in the night its 30% only and i tried to charge it then after 15 minutes i looked a it then it is only 7% why plz make any solutions for that it would help me alot....thank you
Calificación 2
Comentarios:
read my coments and do it it may work for your case dear.
por
your phone battery needs to be waken up when using a universal charger or probably you need to check on the battery terminals of the phone
por
The logs keeps coming up
Calificación 1
Update (06/01/2016)
there's no display card , you will just need to buy a new board buying a new board is like buying a new phone
Calificación 1
Proud with my huawei ascend Y300 until it fell into a cup of tea will not read the sims card continuously getting a display to insert sims card although the phone is dry any ideas also displays emergency calls only any ideas what to try
Calificación 0
i can't switch on my mobile only the huawei ascend name is displaying no other things
Calificación 0
Añadir tu respuesta
Anthony Ng estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 8
Últimos 30 Días: 38
Todo El Tiempo: 2,296
