Saltar al contenido principal
El iMac G5, impulsado por el procesador PowerPC G5, fue lanzado originalmente en el 2004.
Preguntas 517 Ver todo
iMac G5 with intermittent power on
Hi,
I have an iMac that starts up fine most of the time.
It can go for days working just fine.
When it fails, a push to the power button does NOTHING.
Inevitably, if I try enough times it works fine!
Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Probably a failing power supply. To get you to the correct part we would need to know your exact machine. The power supply probably has to cool down before a restart. Open it up and look at where the power leads enter the power supply form the motherboard. If you see a burned area close by, you will know for sure. Opening up this one is usually a matter of three screws on the bottom of the frame. The part looks like this: [producto vinculado inexistente o deshabilitado: IF165-002-1]
Here's how to get to the typical G5 iMac power supply:iMac G5 17" Model A1058 Power Supply Replacement
Again, check your model, it's located on the bottom of the stand.
Fue útil esta respuesta?
Puntuación 1
Comentarios:
The iMac is a first generation 17" iMac and has no burned leads. It has a apple 661-3351 power supply.
You suspect the power supply, but when I run through apple's iMac test procedure,
http://support.apple.com/kb/ht2173
none of the buttons get the cool iMac to start up - when it's in failure mode (like today).
Do you still think it's the power supply?
- de
Añadir tu respuesta
bsmith1 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,072
