The Samsung Gear Live is an Android Wear-based smartwatch announced and released by Samsung and Google on June 25, 2014
Preguntas 9 Ver todo
Why doesn't my watch work after wearing it diving?
The watch is supposed to be waterproof, so I wore it while diving. Now the watch won't turn on. Is it the battery? Or is the watch damaged?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
2 Respuestas
Solución Elegida
Although the watch is IP67 certified, that does not mean the watch is certified for diving.
IP67 means that the watch is certified waterproof down to a depth of 1 meter (approximately 3 feet). This means that the waterproof seal may have failed and damaged internal components while you were diving.
Check inside the watch - on the inside there is a small circle attached to the inside of the watch, near the battery. This circle turns pink when water has entered the device. If you see water, or the circle is pink, then water has entered your device and may have damaged internal components, such as the motherboard, which would cause your watch to no longer work.
Fue útil esta respuesta?
Calificación 4
water+watch= dead watch
Calificación 0
Añadir tu respuesta
Keith Cooper estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 530
