Lightweight cordless vacuum sweeper for picking up crumbs and other small waste.
Preguntas 9 Ver todo
Why won't the SweeperVac turn on?
The Swiffer SweeperVac refuses to turn on.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The most common reason for this happening is a dead battery. The battery must either be charged or replaced.
If it is not the battery, the mechanism for turning on the device might be jammed. This mechanism is in the handle. To check this, try removing the handle entirely and examining the opening at the bottom while pressing the handle button. If it broken, there is little you can do, but is more likely to simply be stuck in which case pressing against the inner mechanism might free it up.
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
Adeoluwa estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 34
Todo El Tiempo: 1,365
