Saltar al contenido principal
Una generación de aluminio monocasco del Mac mini identificable por el número de modelo A1347 o A1993, que abarca desde mediados de 2010 hasta el modelo vendido a finales de 2018.
Preguntas 920 Ver todo
Can the new Mac mini used with car power?
The new Mac Mini teardown Step 22 looks awesome, thank you. I'd like to know if the mac mini can be used with car power. Is it easy to install? As the car battery uses 12 V it should be compatible, don't you think?
Thanks for your answer!
Es esta una buena pregunta?
Puntuación 3
Comentarios:
+ I have certainly always wanted to install a mini in the dash of my Explorer.
- de
Agregar un comentario
5 Respuestas
Solución Elegida
Actually you don't need to mess with the internal power for the mini--just use one of these either plugged into the lighter socket or hardwired to the 12V auto circuit. Ralph
http://eshop.macsales.com/item/Kensingto...
Fue útil esta respuesta?
Puntuación 1
Comentarios:
That's the ticket! +
- de
Respuesta Más Útil
it doesn't matter if the mini has an external power brick or not!
nightrunner is right - the mini uses 12v - that's the important part!
check the power supply unit picture from the teardown: CLICK for a HUGE picture
Puntuación 3
Comentarios:
with a lot of modding, if you plug the mac mini into the car directly without an inverter, it would save electricity (right?) as inverters aren't 100% efficient
- de
The inverter thing would work, it can deliver 120w and the mini has a 85w psu (what the frog?? - this thing isn't that fast, it has no "special" hardware in it). i think the main problem is the heat. the inverter will get hot, the mini will get hot and in a car - it will get hotter sometimes - the first thing that would die is the hdd. modern apple devices can have serious heat issues - so it would be a good idea to remove the psu and put soemthing useful in there. but that would also make not much sense. i don't need a computer in my car, i even hated my dvd players bright screen at night when listening to music. BUT if i wanted a computer in my car - it would be a DFI LANPARTY MI P55-T36 based system, fast, cheap and able to run osx. i hope that apple starts to produce something innovative in the future, design isn't everything - i like computers with good design and a good usability. there is still no small mac notebook with 3g & gps. still no mini with i5/i7. i'm to old to get bedazzled by designed stuff.
- de
I agree with the heat problems. +
- de
Maybe buy some 120mm fans? or 140mm? if you don't mind the noise?
And I agree with the heat problems as well, imagine those hot summer days where the mac mini is toasting under the (probably) black (or any other dark color) dashboard...
- de
I remember a macworld article about someone that had installed a mac mini in their dash of their prius. If that can be done, I think this can be done.
Puntuación 1
I believe it should work, since the power conserter is inside the mac
Puntuación 0
The new Mac Mini does not have an external power brick. The input to the system is straight 110v AC (for those in the US).
Puntuación 0
Comentarios:
If you look at the picture that markus put up, the PSU supports 100-240 volts.
- de
Añadir tu respuesta
nightrunner estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 11,039
