Saltar al contenido principal
Apple lanzó el iPad Air adelgazado y pulido el 1 de noviembre de 2013 en una opción de Space Grey o Silver. Incluye el procesador A7 personalizado y se envía en configuraciones de 16, 32, 64 y 128 GB.
Preguntas 577 Ver todo
Left Side of LCD has shadows/lines after screen repair?
Hey guys,
I've had this issue once or twice now and basically after replacing the glass on an iPad Air, the left side of the LCD has weird shadows going down the side of it. Not sure what caused it as I'm always very careful throughout the repair (expensive devices!) but just wanted to check with the iFixit community to see if anyone had some insight here.
I did a quick search and read about possible firmware issues, although this seemed to be for a different issue than what I'm having.
I'll try to get a picture uploaded soon.
Thanks for any help!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
4 Respuestas
Respuesta Más Útil
I also have this issue. Replaced the LCD and the lines/shadows are still present. Any insight would be appreciated.
Fue útil esta respuesta?
Puntuación 1
Hello loosen the screws this puts pressure on the lcd when to tight and can cause shadows hope this helps..
If screen was grand before fitting and there's a problem after its never firmware issues but the repairs fault
Puntuación 0
I have the same defuse squarish pattern up the entire left side. I sent it back thinking it was a manufactures defect only to have a replacement one do the same thing. It has no pressure behind it. It's not even screwed down. Appreciate any help.
Puntuación 0
Had the same issue, also still present when the screws were not secured. I was thinking it could have been the connector ribbon as I pulled the edge up a bit when trying to take the connector plate off it (I didn't rip the connector but it just pealed at bit from the connection piece), but not certain.
Puntuación 0
Añadir tu respuesta
jon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 1,709
