The Blackberry Torch 9810 is an updated version of the 9800 Blackberry
Preguntas 5 Ver todo
Why won't my phone turn on?
I put my phone to charge last night and when I woke up it was off. I tried taking out the battery, but that was useless. What do I do?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 6
Comentarios:
me too I have the same problem, when I change my Sim Card yasterday, my phone did not open up to now
por
Agregar un comentario
3 Respuestas
First check to insure your charger cord is not ruined. Many times this can be the main reason why your phone isn't charging. Try using a friend's cord or an additional one that you may have laying around. If this still doesn't work you will probably have to replace your battery. That is an easy fix! Hopefully that works, but if not your logic board must be replaced.
Fue útil esta respuesta?
Calificación 0
Heat the panel with paste if it dosnt work change the flex
Calificación 0
when i turn on my phone it's say "error 507".what do i do ?
Calificación 0
Comentarios:
Open blackberry device manager on PC, connect blackberry device using USB cable without battery and continue repair option on PC with blackberry device manager.
por
Añadir tu respuesta
Jocelyn Adorno estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 11
Todo El Tiempo: 2,094
