The Canon EOS 7D was Canon's first high end professional camera with an APS-C crop sensor.
Preguntas 37 Ver todo
My flash won't pop up on my EOS 7d
My flash won't pop up on my EOS 7d, any suggestions on how to fix this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
I have the opposite problem - the pop up won't close - since it was new but hate to part with it to have it looked at
por
Agregar un comentario
2 Respuestas
Respuesta Más Útil
In the flash shoe on the top of the camera, there is a metal spring plate. Under the plate you will find a white cylandars that goes through the hot shoe (about as thick as a paper clip). When an external flash is pushed onto the shoe, this pin is pushed down and tells the camera there is an external flash in the flash shoe. This disconnects the internal flash. Spillage can cause this pin to stick down. Remove the battery, and then put a little Windex on a clean toothbrush and clean the pinhole. Blow lightly to evaporate. The pin should pop up, but it might take a couple of cleaning attempts.
Another cause could be that sticky liquid spillage has gotten on the pivots for the flash. Once again, cleaned with small amount of Windex on a q-tip may free the pivot. One of the pivots is a screw. Sometimes it is rusted, and needs to have the rust scraped off and then a light coating of grease applied.
Fue útil esta respuesta?
Calificación 3
Comentarios:
Thanks for this advice. It was exactly what I needed! You rock
por
Good advice, worked the first time.
por
Excellent solution! 10 sec and it solved!
Thank you!
Calificación 0
Añadir tu respuesta
Andy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 20
Últimos 30 Días: 123
Todo El Tiempo: 3,921
