Why is my tablet not vibrating?
My device does not vibrate while being "ON".
Es esta una buena pregunta?
You should start by checking the tablet's settings. If this does not work, you might have to check the internal wiring of the tablet or check for water damage. Lastly, if none of the previous steps work, then you probably have a problem with the tablet's vibration switch. To remove the vibration switch click on the Vibration Switch Removal Guide and follow the steps.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 959
After doing some research, I believe that I have found the answer to my own question.
- de Gabriel Delgado
