Saltar al contenido principal
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
Preguntas 133 Ver todo
My Galaxy GT-P5110 won't hold a charge or turn on. Please help!
I tried leaving it plugged in overnight, I even took it to the geek squad at best buy, and the samsung salesman...nothing. I bought the tablet in Germany, I don't know if that matters (I doubt it). Can someone please help me solve this issue. Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
This is a copy of another answer I gave today:
Perhaps because your battery is dead.
Check your charger plug-in module with another USB device to see if it is still working.
If your plug-in is still working, check your cable for physical damage, such as a deep crimp in the insulation on the wire (which might indicate that a wire was broken inside), or a dinged-up male for the tablet.
There are 7 pins in the charger cable, buried down in the slots on that 30 pin connector, and the other 23 slots are empty. You might need a magifying glass and a bright light to see properly.
Even if you can't see any damage, a replacement cable is less than 5 bucks: buy a new one and see if it fixes your problem.
Remember if your battery is very discharged that it might take a while for the power-off battery logo to appear on the screen.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Bryant estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 3,260
