How to fix error scanning error can not scan, copy or fax
does not recognize documents in top loader to scan. keep getting error not able to scan, copy or fax. have a macbook air OS X 10.9.5
Es esta una buena pregunta?
pull the power plug and data cable off, then after pushing the power button a few times to clear inbuilt memory, reconnect all cables/power, and try again. Most times this works.
Fue útil esta respuesta?
I had the same problem. This helps: http://h30492.www3.hp.com/t5/Drucker-und...
If the printer does not detect paper in the auto document feeder, then check the feed rollers for dirt that keeps the rollers from grabbing the paper, There should be a paper sensor near the pick up rollers, not to be confused with the cover closed sensors.
Another thing to try, is place a document on the scanner glass. This will test if the scanner itself is working. Works well unless you are faxing, copying multipage documents.
you can also call H.P. for help
they fixed mine for free. 1-800-474-6836
you'll get this recording saying to go to the web site but just wait it will send you to somebody after awhile.
then tell them whats going on and they will help you fix it
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 3,425
When I sent a fax it shows warning and nrver stop and I cannot turn off itt. How to do?
- de Saw Lwin
