Location of backlight fuse on Logic Borard?
Greetings IFIXIT community! I failed to find the correct location given the only post I found is for the mid 2013 13 Inch model, not the 11.6 inch, I find the logic board is different and must ask this question. I recently have taken the plunge with buying this water damaged macbook air, everything works as it should except for the non- existent ssd that was retained by the seller and the backlight for the display. The previous owner claimed that the laptop was subjected to rain inside a backpack that was partially open. When the owner found the moisture they placed it in rice overnight and the next day it worked. Some time later however the computer's ssd would not boot and the backlight stopped working.
I was hoping that someone could point to the precise location of the fuse for the Mid 2013 Macbook air, 1.3Ghz, i5 on the Logic board. The computer's screen works as it should yet the backlight does not. I am confident that there is a way to fix this computer, I know this is a more advanced repair so here I am ready for the next challenge !
I pulled this photo off your website and found that it matches my Logic Board. I am thinking that checking the fuse is the first step. Any other suggestions would be appreciated.
Thanks in advance!
Bret :o)
Edit- Photo of Logic Board Oct 28, 7pm
You can see in the upper corner where the hinge screws are there is some corrosion on the hinge and the screws. The fuse checks out fine.
Es esta una buena pregunta?
