Saltar al contenido principal
Enrutador Apple de quinta generación lanzado el 21 de junio de 2011. Cuenta con conexión inalámbrica n que aumenta la velocidad de la red con respecto al modelo anterior.
Preguntas 13 Ver todo
Why can I not find the Airport network?
The Airport Extreme is on but when I try to connect, I can't find the network.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
3 Respuestas
Respuesta Más Útil
i think you should reset the apple airport.and launch the apple utilities once again .so lets go and setup the airport once again . setup your user name and password and lets connect your all devices .for more information contact Apple airport support and i hope this would fix issue ..thanks
Fue útil esta respuesta?
Puntuación 1
If you are unable to find the wireless network, you can try a few different things. If your router is far away from the device you're trying to connect to the internet with, you may need to move the router. It should be away from walls or metal surfaces as well as devices that may cause interference such as microwaves or wireless phones. If this option doesn't work, you might need to install more routers or signal extenders to ensure that the Wi-Fi signal reaches across your house.
The problem could also be an internal hardware failure in the router. You may need to replace the antenna or the Wi-Fi card. There is additional information listed in the troubleshooting page.
Puntuación 0
See if any of the following articles can help:
Puntuación 0
Añadir tu respuesta
Jada Evers estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,801
