Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 4098 Ver todo
Home button click function not working when pressed
Hi all,
Had a water damaged 5S which I ended up taking apart and replacing the screen on.
All back together and (mostly!) working - ironically the touch ID works OK but the home button normal pressing function doesn't.
I've looked at the cable and was very careful with this all through - what have I missed ?
Dock connector won't currently charge or connect either but that was working when I tested the assembly prior to the screen being replaced.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Well you may have a case of thermal phimosis. It's simple dude :p
The ribbon has been partly shorted out due to the water damage.
With the charging port I would go for the same concept. Remember that water doesn't necceserily damage until it reaches certain temperature due to its composite density.
When you charged it the first time it was enough to ruin the rest of it.
Fue útil esta respuesta?
Puntuación 0
Comentarios:
Disaster averted ...
I realized that, eventually, none of the bottom items worked, IE the headphone socket, the speaker etc.
The bottom loom was damaged partly by the water and partly by the plug parting company. The home button plugs into this loom and had therefore partly stopped working.
I replaced the loom across the bottom, with a new lightning connector and the home button now works perfectly.
Looks like things could have been considerably worse!
Lesson learned ....
- de
Añadir tu respuesta
aceman72 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 143
