Saltar al contenido principal
El LG G Watch es un reloj inteligente ponible con Android anunciado y lanzado por LG y Google el 25 de junio de 2014
Preguntas 13 Ver todo
Why isn't my battery charging?
When the adapter is plugged into a working outlet and the watch is docked onto the charging station the watch does not "wake" and start booting up which indicates that the battery is charging.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
If the device does not detect the charging station when properly docked it is most likely due to a common issue with the charging pins. The charging pins on the LG G Watch easily become corroded when they come in contact with sweat or water. In this case the charging pins will need to be replaced in order for you to charge your LG G Watch
Fue útil esta respuesta?
Puntuación 1
1 comentario:
how and where they can be replaced
- de
Called LG, they said they do not sell internal parts. So unless you are an authorized repair center, forget it.
Puntuación 0
1 comentario:
I think it's unacceptable that LG won't service a watch which is less than 3 years old.
- de
Añadir tu respuesta
Deja Miller estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 685
