Why does my computer fail to run high end software?
I am trying to use my computer to play games and occasionally do some video editing. Many times I get an error report that says insufficient memory, how do I fix this?
Es esta una buena pregunta?
Aaron,
You are most likely experiencing this problem due to having insufficient random access memory (RAM) chips in your laptop. This is a very simple hardware fix that involves buying more RAM and should not take very long. After purchasing a new chip with more memory, remove the large plastic cover located on the bottom of your laptop. You will have access to your RAM once the plastic cover has been removed. Pull the RAM chip out of the mounting and replace it with new chip. For further disassembly/replacement information, the W350I device troubleshooting page will be helpful.
I hope this helps!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 165
