Home button sticking after screen replacement
After sitting the screen down fully the home button sticks. When i lift the glass up a fraction it doesnt stick but when i seat if flush it sits.
Any ideas?
Es esta una buena pregunta?
Pantalla de 7.9 pulgadas / Modelo A1432 / Disponible en blanco o negro / Anunciado el 23 de octubre de 2012/16, 32 o 64 GB de capacidad
Any ideas?
I've found the metal frame under the home button to be causing the issue. Slightly bend the frame away from the home button and it should work properly
I have the same issue.... frustrating!
Seen this issue once before and I just took the plastic button off the original and fitted to the new glass being careful when lifting up the home flex and then worked 100%
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 1,467
