7" multimedia tablet by Barnes & Noble, released in November of 2011. Fixes are easy and require simple prying tools and screwdrivers.
Preguntas 50 Ver todo
My nook tablet Won't turn off
My nook will not turn off...I have tried all the reset options. ..I hold the power button down and nothing happens. It still works fine. ...but can't take it traveling. Help it's only 2 years old:( hope you can help! Thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 4
Comentarios:
Hi , this is happening to me to . I have a nook Hd and it won't turn off . If you fixed yours please let me know / how .
por
Are you sure the power button still works? Have you tried doing a factory reset or upgrading the software?
por
i have this same problem any other way to turn the nook off besides the power button?
por
Im having the same issues. Also freezes on me
por
My nook is frozen in the "sleep" mode. I've taken the battery out and it is still frozen in sleep mode. Don't know what to do.
por
Mostrar 1 comentario más
Agregar un comentario
3 Respuestas
Check these sources:
http://www.dummies.com/how-to/content/ho...
http://smallbusiness.chron.com/access-fa...
http://cp-barnesandnoble.kb.net/?search=...
(Or read the article below made by Barnes and Noble)
An unresponsive NOOK may exhibit the following symptoms:
· Image stuck on the screen
· Unable to power off
· Unresponsive to button or touch screen commands
· Unresponsive after fully charging
If your NOOK is unresponsive, complete the following steps:
NOTE: Removing the battery from your NOOK may void your warranty. Review the warranty for your particular NOOK for details.
1. Confirm the microSD™ card slot is empty.
2. Press and hold the power button for 20 seconds, then release the power button.
3. Press the power button again for 2 seconds to turn on your NOOK.
4. If unsuccessful, charge the device via a wall outlet using the USB cable and AC adapter for several hours. You can also try plugging your NOOK into a computer via the USB cable.
5. Once fully charged, attempt to power on. If the device does not power on, press and hold the power button and the "NOOK" button at the same time for 20 seconds.
6. If your NOOK does not power on after charging, it is recommended to attempt charging using another outlet and USB cable.
NOTE: If another NOOK is available, attempt to charge that device using the current outlet, charger, and cable set-up. This will help determine if there is a problem with the device or charging conditions.
7. If your NOOK is still powered on and will not power off after completing the previous steps, leave the device on and allow the battery to drain completely. Once the battery has completely drained, the NOOK should power off and the screen should go black.
8. Charge the device via a wall outlet using the USB cable and AC adapter for several hours.
If your NOOK remains unresponsive after all troubleshooting is exhausted, please attempt the following:
NOOK HD/NOOK HD+
The following procedure details how to perform a NOOK HD/NOOK HD+ factory reset. A factory reset will deregister your device, removing all digital books and files, including side-loaded content. The NOOK titles you have purchased will remain in your account and can be downloaded again.
NOTE: We recommended that you back up all side-loaded content you wish to save to an SD card or computer before proceeding.
1. Confirm the device is powered off and that the microSD™ card slot is empty.
2. Hold the Power and Home key simultaneously.
3. Release the Power and Home key once the NOOK logo appears.
A Factory Reset prompt will appear.
4. To continue with Factory Reset, press the Home key.
5. To cancel, press the Power key.
6. Once reset begins allow 1-2 minutes for completion and your device will reboot to the start up screen.
For steps on re-registering your NOOK please click here.
NOOK Color/NOOK Tablet
The following procedure details how to perform a NOOK Color/Tablet factory reset. A factory reset will deregister your device, removing all digital books and files, including side-loaded content. The titles you have purchased will remain in your Barnes & Noble account.
2. Hold the Power and Home key simultaneously; A grey NOOK logo should appear. Continue to hold both buttons down and release immediately after the screen turns black.
3. If successful, a grey NOOK Logo will appear and the screen will refresh momentarily and flash yellow. A Factory Reset prompt will appear.
4. To continue, press the Home key.
5. To exit, press the Power key.
Hope this helps.
Fue útil esta respuesta?
Calificación 0
my nook hd will not turn off nor return to factory setting when the power button is pushed nothing happens can the power button just stop working/. when it is fully charged the nook works fine just wont turn turn off
Calificación 0
quote : "".......when it is fully charged the nook works fine just wont turn turn off.....""
Did you know that there is a setting option to prevent the display turning off while it is charging?
To check whether this option is set or not set goto SETTINGS / DEVICE INFORMATION / /DEVELOPER OPTIONS then check whether the 'Stay Awake' box is ticked. If so untick it.
Hope this helps.
Calificación 0
Añadir tu respuesta
Patricia bengford estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 35
Últimos 30 Días: 179
Todo El Tiempo: 11,795
