Why is my Device not turning on?
I plugged My MultiPro in and no matter what I do it will not turn on. The bit will not rotate and the device seems to not be getting power at all. Can this be fixed?
Es esta una buena pregunta?
Yes, this problem can be fixed. Ways in which you can fix your dremel and get it to power on are, Making sure the dremel is plugged in, make sure the brushes are properly cleaned, and make sure the stator wires are making a connection with the connector.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 2,082
