Why is the drill not powering on?
Every time I try to turn on the drill it seems as if it is not getting any power. The chuck does not spin and the trigger doesn't budge.
Es esta una buena pregunta?
You may need to charge the battery or replace the battery if it is bad. Also, if the direction switch is in the center position, the trigger is locked and the drill will not function.
Fue útil esta respuesta?
It is possible that your battery may not be charge sufficiently. Take off your battery and place it on the charger and wait for a full charge. Once fully charged put the battery back on the drill and check to see if the drill gets power.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 268
