Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 4094 Ver todo
Cracked home button, Touch ID not working?
Hi there! I had a 5S that got ran over a couple times, destroyed the digitizer and lcd, and cracked the home button. Replaced with a new display assembly, moving the old home button over in the process. Phone boots up fine, digitizer and home button works great, but Touch ID does not function. Could it be because the sapphire is cracked? When I go to enroll a fingerprint, it immediately fails. If anyone has a functioning Touch ID with a cracked home button please let me know. Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Immediate failure of Touch ID means the system cannot establish communication with the sensor. The chip under the button is not properly initialized or was already destroyed.
Bad initialization can be fixed by resetting the device, destroyed chip... There is literally no one can save you.
Fue útil esta respuesta?
Puntuación 2
Comentarios:
Thank you! Will try to reset device and reconnect cable a couple times, otherwise I guess the chip is toast.
- de
Is the spring contact required for touch id to work?
- de
Añadir tu respuesta
Jared estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,354
