Saltar al contenido principal
2.26 o 2.4 GHz / Carcasa Unibody de plástico blanco
Preguntas 645 Ver todo
Rear Speakers - Sound issues
Hi Guys,
My macbook sounds noisy and unclear. But, on head phones it very good. Will it be a hardware issue? or could it be software related?
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Could be your speakers. should not be a software issue since the audio IC will remain the same. Could be a preamp issue. I'd go check the speakers first.
- de
Thanks mate.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Did someone spill a drink into the keyboard? I've had a few systems which had soda spilled which with the dust from the fan messed them up.
I would start by doing a good job cleaning up the dust within the system and replace the speaker. If something did get spilled you'll need to clean it up as well.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
Hi Dan - Did not spill anything. I started noticing this over the past 3 months and I thought this could be because of Windows 8 I am running as dual boot. Thought it might to do something with drivers?
I tried cleaning the Fan and pulled out the rear speaker and cleaned it , but no luck. Do you think, it is just the speakers' hardware? and I get this irritating noise when the volume is above 70% , below, its difficult to hear anything :)
- de
Is it a buzzing sound? It might be something loose which is vibrating when the speakers volume and/or tone is just right to set it off. I've found loose parts are often the cause. See if you can find a tone generator app to walk through the different tones. Something like this: AudioTest
- de
Frankly, the built-in speaker is not very good in this model. You might find a JamBox or other plug in external speaker will offer better fidelity.
- de
Añadir tu respuesta
Srini Krishna estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 271
