Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, and a better design.
Preguntas 329 Ver todo
My right trigger button isn't working
It still registers but it doesn't have the same sort of springy feeling. Its worth noting I think started after a fall on the trigger. I'm guessing some piece of trigger assembly either broke or got out of alignment. Unfortunately I can only seem to find on trigger repair guides for the 3DS and those seem to be about replacing a flex cable not a mechanical issue (presumably they wore out the actual electrical switch component).
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
ABRIR TODAS LAS PESTAÑAS
Kits de actualización de RAM para Mac
Compra kits
Suficiente RAM
para todas las pestañas
Compra kits
1 Respuesta
Solución Elegida
Usually after a fall the plastic around the button gets bent into the button a little bit or sometimes the button part that is inside the console rubs on the plastic.
What I do is inspect it very carefully around where the button is and find where it is sticking. They I either try to bend it back or I remove a small amount of plastic with a hobby knife or razor blade until it moves freely again.
This fixes the vast majority of these types of problems.
I hope this helps.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Nathan Saslavsky estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 29
Todo El Tiempo: 1,087
