Saltar al contenido principal
El portátil Dell Latitude E6500 se lanzó en agosto de 2008. El Latitude tiene un disco duro de 15,4 pulgadas con 500 GB
Preguntas 21 Ver todo
I need to disable the PW on my laptop...
On my old desktop, via the motherboard. There's a jumper pin to disable the PW. Is there one on a Dell E6500 Latitude, and do you have a schematic of the MB and a list of the surface mount jumper designations?
Hurry...
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Kevin Wilson, no there is not one. /most modern laptops no longer store the password in battery-backed RAM. those were the once you could reset by pulling the battery or a jumper setting. More modern motherboards use standard SPI flash chips to store the BIOS data. You should contact Dell and once you prove you are the rightful owner, they will help you. There may be a few ways to get it reset with your Service tag number. Check on here. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thanks for the assist.
- de
Añadir tu respuesta
Kevin Wilson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 2,027
