La PlayStation Vita es el sucesor de la PSP. Contiene un procesador y gráficos mejorados, e incluye la adición de un segundo stick analógico. Fue lanzado el 15 de febrero de 2012.
Preguntas 122 Ver todo
Ps Vita, Battery solder
I was replacing a analog stick on my ps vita. When I tried to remove the battery the clip that connects to the motherboard, it came completely off. Is there a way I can solder the battery wires directly to the motherboard. if anyone can help I would appreciate it. Please Help.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
6 Respuestas
Respuesta Más Útil
Hello I did the same mistake, i wanned to unplug the battery and replug it (i had battery issues) and i broke the solder (actually the black plastic part at the top that hold the wire) so now i can't connect the battery to the motherboard anymore.
Here is a picture of the black plastic i broke :
http://i.imgur.com/YOiIPhQ.jpg
Fue útil esta respuesta?
Calificación 1
somebody help please
Calificación 1
Hi, this might come too late but, just below where the battery connecto once stood, there are three solder points correnponding to each of the battery terminals, just solder the battery directly there...
Calificación 1
Comentarios:
Hi Estuardo @taquito77,
Thank you very very much! I now have a working vita!
For the others that possible will view this post the 3 solders joints are straight forward the conector scheme.
por
Have you got a photo so we can see the extent of the damage ? If your in the uk i have a couple of boards knocking around
Calificación 0
Mike, I had the same problem. Or at least a similar one. I was separating the two halves to replace the battery and the entire white plastic cradle part that attaches to the motherboard just came off the circuit board. It came apart effortlessly! It was as if it was barely attached to begin with. Poor quality circuitry!
I'm hoping for an answer here as well. I'm willing to solder if that fixes the issue.
Calificación 0
I just did this to mine and I wanna cry TTATT The white part on mine broke in half too. . .
Calificación 0
Añadir tu respuesta
Mike estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 5
Últimos 30 Días: 45
Todo El Tiempo: 1,110
