Saltar al contenido principal
Portátiles HP diseñados para uso doméstico y doméstico.
Preguntas 1033 Ver todo
Pregunta Cerrada
Caps Lock and Num Lock LEDs blink continuously, can't get to BIOS
On my HP Pavilion tx2525nr Notebook PC (Windows 7 professional), the cursor LED and Caps Lock LED blink continuously. The laptop won't start and only shows a black screen. Also, I cannot get to the BIOS menu.
Update
I could not boot to an install disk.
Es esta una buena pregunta?
Puntuación 34
19 comentarios
Can you boot to an install disk?
- de
Same problem, but fixed it by installing a new BIOS. see this link: http://support.hp.com/us-en/document/c02...
and follow from step 2.
- de
HP62 64bit Win7 wouldn't boot/cap lt blink/black screen. Solved by removing SD card from slot.
- de
I'm using win 10 and this happened but it goes on to the login screen, I'm completely hopeless because i cant log in.
- de
This is caused by the typing language selection option. For me a quick WINDOWS+SPACE resolved it.
- de
Mostrar 14 comentarios más
Agregar un comentario
22 Respuestas
Solución Elegida
First thing to do (as suggested by HP also) is: turn off your PC, unplug the charger, take out the battery, then open the RAM slot.
Take out the RAM and disconnect the wireless card.
Press the power button at that point, and keep it pressed for like 30 sec.
Reassemble it all and try to boot.
It may be a power problem or BIOS failure. Try this out; afterwards, it should be OK.
If that does not work, the worst scenario is that you just reset your BIOS from CMOS by taking out the small battery behind the RAM modules for a few seconds.
Hope the info helped.
Fue útil esta respuesta?
Puntuación 71
59 comentarios:
Thank god, I followed these steps, and my computer is back up running
- de
It worked perfectly. Thanks!!!
- de
Thank you so much. My computer has been dead for over a month. Tried what you said and its back.So simple I couldn't believe it.
- de
Sorry. This fix got my led's blinking properly. Then I held down the four arrow keys and turned on lappy. This got my screen back. Don't know why but it worked.
- de
That's Work. Thanks a lot.
- de
Mostrar 54 comentarios más
press with you palm on the center of the keyboard especially at the area 'T,Y,U,I,O,7,8,9'. This is due to the GPU socket loose.
Puntuación 18
14 comentarios:
turn on computer and the keyboard num lock is blinking what dose it mean on my compaq
- de
This worked for me one time, enough to do some backup. Thanks.
- de
how ? what mean by palm? i have the same problem in my hp g62.
- de
Great Wow.. amazing.. it works... Many thanks...
- de
Incredible!! Worked just now on a Pavilion dv7 which didn't start up and with a 4x BIOS blink code...
- de
Mostrar 9 comentarios más
Give it a little TLC. Kinda like administering CPR chest compression's but, much more lightly and gentle. Pressing with you palm on the keyboard area keys T,Y,U,I,O,7,8,9. It really works!
Puntuación 8
15 comentarios:
I tried this and to my amazement it worked, but only once so at least I could backup some files . Thanks.
- de
how to do it? pressing with your palm mean?
- de
Worked for me! Thx Lori. @Waqas Baber "Kinda like administering CPR chest compression's but, much more lightly and gentle". As simple as that.
- de
I love you, you saved my life, you solved my problem and when I held down, I hard some clicking sound and now my laptop is working
- de
- de
Mostrar 10 comentarios más
Check your ram modules.
It is either loose or they are dead.
Remove the Ram modules, wipe it with a lint free cloth, put it back in and see if the laptop is working.
If not you will have to replace the ram module(s).
Puntuación 4
3 comentarios:
I have done all these procedures,but to no avail. i have used new ram modules.....,
- de
Both of my Ram Modules were bad. replace with other and booted just fine. Thank you for the idea!
- de
Wow amazing. Absolutely super i got my screen back just putting my ram correctly. Thank you
- de
I have been a tech for over 40 years, and I'm telling you that overheating the laptop is NOT going to cause the solder to melt, or the joint to work. In fact, when troubleshooting a thermal problem, the opposite is true. "Cold solder" connections FAIL as the unit heats up. To isolate the problem, a freon spray is used to cool suspected areas to see if the problem disappears. So all these posts all over the forums regarding this machine that claim overheating the unit causes bad solder joints to to reconnect temporarily are WRONG ! I have no doubt that this method does sometimes get the unit to temporarily boot, but not for the reasons they claim. I do not know the reason for the original failure, nor why overheating the unit gets it to boot, but I suspect a fan issue, or some other error message being sent to the cpu that stops the start process. One of my ram cards slot is extremely loose, and the machine doesn't react differently if there is 1,2, or no ram cards installed. I will continue trying to isolate the problem, but I suggest if you want to recover data on the HDD, get an external hook up and do it right, not by frying you laptop further !
Puntuación 3
2 comentarios:
you are most likely correct and this ty0pe of fix (if it works the first time) should never be counted onto work again. Time to get a new laptop ! :)
- de
I am a tech of about the same number of years and I'm here to tell you that it will. It doesn't technically "melt" the solder, but over time, extreme overheating and then cooling off quickly, causes the cheap solder that HP uses to crack and that's a fact. The solder that HP and many other manufacturers use, is substandard and melts completely at temps that would not begin to melt any decent electrical solder. The cracking causes the GPU to heat up expediently hotter due to the failing connection, until the connection is finally lost.
I have examined the boards under a microscope and you can clearly see the stress cracks. Hence the reason that the only way to fix these machines is to reball the solder on the GPU and add an appropriate thickness copper shim to the GPU, so that it has ample pressure applied and is conducting heat as efficiently as possible.
I have done this to HP laptops numbering in the hundreds and if the GPU is not too damaged from heat, it almost always solves that problem.
- de
For three blinks: Remove battery for few mints and reinsert it. During boot process press shift+ctrl+alt. It worked in my laptop (cq40) many a times. Although it is not my idea. I read it somewhere (can't recall). But it worked. Just removing battery and pressing any other buttons did not work in my laptop.
For four blinks: I removed RAM and inserted it again. Laptop started.
Puntuación 3
3 comentarios:
I have tried EVERYTHING on HP SITE And this worked immediately! Thank you for sharing!!
- de
I am happy that it helped you. :-)
- de
Thank you very much!! It worked perfectly
- de
You have burnt out the Graphics chip on it, i am amazed it has lasted this long as these model are prone to gpu failure.
Simply put.
Under the gpu there are small balls or solder prob 200 of them and a few have melted and joined together shorting out the chip or the heat has lifted a section of the chip, same result dead gpu.
Wrapping it in a sweater just heats up the solder until it turns back to a semi fluid and the solder balls reflow back to the correct position.
Pressing on the keyboard also does exactly the same thing as in that instance the chip has lifted and you are just pressing it back down.
Eventually the solder will fail completely as HP are renowned for using cheap chips and even cheaper solder ( other manufacturers are also available).
You need to have the gpu reballed or replaced, NOT reflowed.
The HP DV, TX, CQ and now the G6 and G7 series all suffer from gpu failure.
Puntuación 2
1 comentario:
Disconnecting the power supply, removing the battery, pressing the "on" button for 45 seconds and reconnecting the power supply worked for me!!!
- de
happened to me too. i disassembled my laptop with no luck. i found out later that removing the SD card i had inside solved the problem.
Puntuación 1
2 comentarios:
I had the blinking light problem indicating a bios failure. After reading this, I removed the sd card from the slot and tried to reboot. It worked.
- de
Shal'aam Aleichem
I'm a retired auto mechanic and would rather repair my own stuff. Computer's are no exception, so any help would be appreciated. My home PC acted like this an after removing the RAM, cleaning the ends with an eraser and reinstalling it has been working fine since (that was three years ago). However, going the same with this HP C-52 Compaq Presario just isn't cutting it.
I tried removing the Batt for a few min's, reinstalling, booting up, nothing, caps look just blinks steadily. Then I tried unplugging the unit, removing batt, removing the RAM, reinstalling, rebooting, still blinking. Tried again all the above, but disconnected the internal batt, reinstalled everything, rebooted, again nothing.
In each scenario I hadn't removed or disconnected the WIFI card. I don't know where it is. Also the SD card, where is it located> Any help is appreciated.
Baruch haba b'shem YaHuah
AAPiY
MiKaEl
- de
I have same issue from time to time (and it's happened several times) with an HP DV7, numlock and caps lock start flashing. All I do is unplug, remove battery for 2 or 3 minutes, re install battery, voila! I have never had to disassemble anything else.
Puntuación 1
1 comentario:
VERY HELPFUL.
fOLLOWED THE STEPS AND REMOVED CMOS AND AM FINE.
- de
On my HP8530w, the capslock and numlock leds blinked 3 times, periodically. It was miraculously solved by the first proposed methods: removing batter, ac power, bios-battery AND wireless card (under the keyboard, near letter B) and pressing the power button for 30 seconds. After reassembling, the bios seemed to be reconfigured and booted normally afterwards!
Puntuación 1
2 comentarios:
Compaq Presario CQ-45 Caps lock LED blinks continuously and wont start,with a black screen, also one can not get to the BIOS menu.
Please help me urgents
thanks in advance
- de
Pls this didn't work on my Hp G61... it still blinks the light beside t cap lock...
- de
I have a Compaq Presario CQ61 that was upgraded to Windows 10 a few months ago, which is when my problems started. My Num and Caps lock keep blinking w/o end and no POST beeps. I tried removing the RAM but no POST. I tried powering the laptop with only the AC adapter and then with only the battery and still only the flashing Num and Caps lock. What finally worked was holding down the Ctrl-Alt-Delete keys at the same time and then powering on the laptop. It booted right up and began installing Windows Updates. I'm wondering if the Updates had something to do with its behavior. Considering taking this laptop back to Windows 7 with a clean install and getting rid of this crappy Windows 10 once and for all.
Puntuación 1
2 comentarios:
My g'friend how win 10 also an it's pure crap. I have win 7 on an old Presario C-52 and it's worked (up until now) fine. Her win10 started acting up 2 weeks after she got the computer. Total POS.
- de
I have tried almost all of these methods, but I heated the pc and pressed the ctrl + at + del and viola! My hp probook 6560 booted straight up. Thanks man!
- de
I found that the memory slot (memory bank) 0 - under the very first slot you see when you open - did not work. I just removed the memory from that slot and let the only one that worked fine and had the biggest memory inside the other slot. The notebook booted okay. But I did not find why just one memory slot stopped working... I will look at the motherboard to see the connections (bus) to the processor and check if there is a short circuit or something like that. Hope this helps.
Puntuación 0
1 comentario:
I solved my problem the same way. It wasn't the memory it was the memory slot.
- de
check the blink codes, if the blink codes are a sequence of 1 and a long delay. that decodes to the CPU not funtional. it is either the cpu itself that is having the problem or the CPU socket is not working. in that sence you need to replace one or the other.
Puntuación 0
7 comentarios:
HP notebooks key to blinks on startup - HP says 1 blink = CPU problem, 2 blinks = BIOS, 3= Memory issue, 4 = Graphics, 5 blinks and it means your system board is dead, 6 blinks = BIOS problem.
- de
to clarify 2 blinks BIOS corruption, 6 blinks BIOS authentication failure.
- de
My go stream blinks none stop
- de
How do i solve bios problem if my pc cant start,, it end op on dark
- de
hello pls how can i solve this prob... my hp 625 stuck on black screen and the caps lock led blinks 5 times and stop but the power led and wifi led stay on... pls help
- de
Mostrar 2 comentarios más
If it comes on and doesn't do anything but stay on the black screen, and caps lock keeps flashing, a weird trick to get it to come back on is to overheat it.
Wrap it up with sweaters or leave it on in your bag for about 30 mins and it will overheat and turn itself of due to the CPU overheating. Then it may come back on.
Its not a permanent fix, but it works for me. I use Sleep instead of Hibernate now and the trick works more often.
Got it from here:
http://h30434.www3.hp.com/t5/Notebook-Ha...
Puntuación 0
1 comentario:
- de
La respuesta fue originalmente a otra pregunta.
Let me start by saying NEVER use a hairdryer for a reflow job, it will never get hot enough, you cannot control the spread of the heat and it can cause damage to the surface of the motherboard.
Understand you may have made things worse.
Have you tried to power it on without the battery inserted?
Cmos battery should be removed for at least 5 minutes.
If the Cmos battery pops in you should consider replacing it altogether. Most main board will not boot if the battery is dead.
Remove battery and power plug hold down power button for 1 minute, keeping it held then insert the power jack to the laptop and see if it boots.
Did you try to power it with hdd removed?
Try to rotate ram. Remove Ram 1 and place Ram 2 into slot 1 and boot, if the same. Remove Ram 2 from Slot 1 and insert Ram 1 in Slot 2 and boot.
Is there a system to the flashing lights? e.g Blink 2, blink 1?
Try these 1st and see if it helps. Let me know how you get on.
Puntuación 0
Glad that some of these fixes work. My problem, however, was a bad GPU connection after a hot summer. After trying everything else, I covered the vents with a cloth and let my G62 heat up for about 10 minutes - turn the computer off then on and it booted properly (GPU connection expand a bit & connects). Knowing this, I ordered an exact match motherboard for $50 from an ebay site and replaced it using a well-done youtube video for the G62. Learned a lot. Cleaned the fan and used high-quality thermal paste for CPU & GPU. It took some time and patience, but the computer is better than new. It helped that HP G62 series is common & MB was exact match shipped from China for free. I am no longer fearful of taking a notebook computer apart. I can give specifics to anyone who wants to proceed. - Peter
Puntuación 0
1 comentario:
Shal'aam Aleichem
I have an even older version. I have a C-52 Compaq Presario and the caps lock just steadily blinks, screen completely black, WIFI light off.
Tried just about everything except ed disconnecting the WIFI card an/or theSD card.
I haven't the foggiest idea where either of those cards are located? The RAM card are easy as is the internal battery, but the WIFI and SD card I can't find just by removing the RAM cover.
AAPiY
MiKaEl
- de
hi , thanks a lot!!! my hp envy m6 ts 15 sleekbook I5 4thgen ,no power on... only power button white and wireless amber ... 4 second up no video no fan no hd and power off.
i disambly completly and check all parts when assembly. and the error continue,,, i tried power on 200 times never up.
i read on your post... press gently on keyboard arround keys.... not work ... but the idea s very good! i tried every zone of keyboard with this method and not result.....
but ... when press with palm the sector of keys limited by 4 a 7 and function keys abvove... and all sector of speaker superior.... the power button still white and not turn off when past 4seconds...
i release the palm and poower button continue on white.... and then press it and power off .
i power on normaly , and advertice of cmos bios bla bla bla... and press enter reboot and my envy func ok !!
i suposse a soldering problem...
gracias from argentina
sorry for y bad english , i try to share my experience with us. thanks.
Puntuación 0
I have done everything written here, but my hp elitebook 8570p is still not booting to windows. And still blinks the caps lock and num lock 5 times before restarting. Can anyone help please
Puntuación 0
1 comentario:
I have tried everything possible, but my hp elitebook 8570p is still stuck on restarting after the caps and the num lock blinked 5times. What do I do
- de
I’ve encountered similar issue with an older HP Elitebook 2540p - the notebook wouldn’t go to BIOS and restarted itself every 10 seconds or so. The LEDs blinked during each cycle. When I replaced CMOS battery (CR2032 type, it’s hidden under the keyboard), the notebook works normally again.
Puntuación 0
I encounter similar problem. Solved it by dismantling the laptop, locating the CMOS battery removing it. Waiting for 10 minutes, inserting it in and wow, it worked. My screen came back.
Hope this process works for you
Puntuación 0
1 comentario:
My pavilion X360 has a blank screen when turned on but the caps lock keeps blinking what can I do
- de
Kindly help pressing the power button only the power, Internet and volume buttons light few seconds later the fans produces a lot of sound continuously, the screen does not light and the Led light below the keyboard at the sd area does not light at all
Puntuación 0
Dear Mr.
I have Lenovo g50-70 core i7 laptop. on my laptop the following error are occurred?
when, I press the power button it gives fan sound and display power light. but after some minute it become shutdown.
can You help me how can solve it?
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 36
Todo El Tiempo: 555,847
