a white line in the middle
found a white vertical line in the middle with it only bought for 4 months, can it be repair if bought back to apple?
Es esta una buena pregunta?
Probably not unless the Original Owner had Apple Care and extended it to you. Or you purchased this from a store or refurbish site, or with a Credit Card (Credit cards do offer warranties, and if you contact them they may be able to assist you in resolution/restitution with/from the seller). You can go to or contact Apple for an estimate - they may cover it.
Have you verified the line does not appear on an external display? If it does you have a GPU/VGC logic board issue.
On these machines the "DIY fix" for a bad display is to replace the entire display (display & cover are all one unit).
If this answer is acceptable please remember to return and mark it.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 710
