Saltar al contenido principal
El Honda Accord de séptima generación
Preguntas 101 Ver todo
02 sensor has no power on wire going in...
HI, my Honda accord 2003 2.4L i have a code po135, i no is the sensor bank 1-1, my problem is i don't get any power to the wire going to the sensor, i check the wire and seems to be oh. so any body have any suggestion what it could be? thanks.....
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
vitodeluca, check these fuses first:
No. 19 OPTION (40 A) fuse in the under-hood fuse/relay box.
No. 4 A/F SENSOR (15 A) fuse in the under-dash fuse/relay box.
No. 23 IGP (7.5 A) fuse in the under-dash fuse/relay box.
Also, Oxygen Sensors need to reach a minimum operating temperature of 750 degrees F to produce an accurate voltage signal. In order to achieve the require temperature, a heater element is included inside the heated oxygen sensor. The ECM controls the heated oxygen sensor heater element. It controls the heater element circuit by allowing current flow to ground.
So, your P0135, could be a bad sensor, but also a bad ECM etc. I would suggest that you replace the O2 sensor and then recheck to see if it clears the error.
- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit fuse
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit poor electrical connection
- Faulty Engine Control Module (ECM)
Information on this is found here and also check this video for interpreting O2 sensor code.
Fue útil esta respuesta?
Puntuación 3
5 comentarios:
How can I locate Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit fuse in Honda Accord 2004? Please need your help
- de
My friend helps me to check, there is not enough power from the source, lower than 1V instead of 12V, he said might be the ECM issue. I hope not, ECM cost a lots to change.
Do you think it is a fuse issue? I have a small problem which cause my 7.5A fuse broken when connect my back up camera, my then the issue light up for O2 sensor.
Regards,
Andy
- de
Would these fuses work for bank 1 sensor 2 as well?
- de
check the relay, seems common issue if sensors are ok
- de
Which relay should I check? I’m having same issue. No power going to o2 heater and no blown fuses.
- de
I also have a 2003 accord 2.4 with the same code. Inside fuse panel did not have a F4 laf fuse. The car sputters in idle. I replaced the o2 sensor and cleared the codes and still have the same code and spotter. My question is if there was no fuse in the F4 section laf heater fuse do I go ahead and put one in it's location? Also is it only on certain models that have this fuse?
Puntuación 1
1 comentario:
Are my 02 sensors faulty, I no reason at all it just says 0 0 0 0 0 on my scanner
- de
Añadir tu respuesta
vitodeluca estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 26
Ultimos 30 días: 196
Todo El Tiempo: 67,659
