Starter won't come out
I took out the 2 bolts to the manafold and the starter will not come out... Are their more than 2 bolts holding it in. All other cables and all are taken off...
Es esta una buena pregunta?
Hey mate, there should only be a short and a long, 14mm bolts and the two electrical connectors holding it in. Make sure you have removed two 14mm and not 2 10mm bolts. If you have, just give it a bit of a jiggle or lightly tap it with a hammer and use a long pry bar, but be careful not to be too rough.
Hope it helps
Fue útil esta respuesta?
Where is the long bolt located
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 585
