Why does washer keep rinsing during spin/dry cycle? Solved
Hello, thank you for any assistance.
My Kenmore washer has two things going on.
First "new thing" is it agitates during initial water fill. Never did that before. It would normally fill properly to selected level... THEN start agitating. Now it just starts agitating second I turn it on.
Second thing is it continually adds water through rinse cycle AND spin cycle. So I get a water soaked load of laundry at end of spin cycle.
What part could I replace to correct the problem with the continuous rinse during spin/dry cycle?
Update (06/24/2016)
Well, after reading repair boards/forums for days! I tried what someone suggested. It worked! All it cost was $7.
Go to AutoZone or Advance auto. Buy a can of CRC Lectra-Motive electric parts cleaner. Then go open the washing machine you can watch a YouTube video how to do it. Basically remove the two plastic side retainer pieces. Remove screws and clips. Get to the electronics. Spray down all control boards and connection plugs you find. It's basically having a bad connection or jumping do to years of humid conditions, dust, vibrations. I am not sure which part or wire connection was at fault. Like I said I sprayed all I found.
This cleaner is potent! Respirator recommended. Fan a must! Fan helps dry everything I sprayed. After spraying I left fan on high for 3 hours blowing into the sprayed parts.
Then I clipped the connections back together. Then put everything back together. Did a test load and BAM it was fixed. $7. No parts. It has been running perfect ever since. I can't even remember when I posted this.
It's NOT hard. YouTube video on opening unit. Get the CRC Electric cleaner and do it.
Our w/d are 1998 but we keep them clean. No reason to but new ones. The only other repair was the "dogs" on the agitator... it's a wear item. Kenmore/Whirlpool are great machines. NEVER BUY THOSE STUPID FRONT LOADER MACHINES! Keep it simple. People. BAM
Good luck!
Es esta una buena pregunta?
6 comentarios
So almost 2 years it's been operating flawlessly. Nice!
- de Randy
Randy I think I owe you a beer.
- de irishchefdude
Have you been able to figure out how to fix the extra rinse your machine does at the end of the cycle? Im having the same issue.
- de Bonnie Mills
Why does water come in on spin cycle?
- de Bob St Onge
I have been trying to find the YouTube video which shows what you have described, but can't find exactly what I need. Can you possibly provide a link? Did you remove all connects from their part before spraying?
- de Kathryn Amrhein
Mostrar 1 comentario más
