Saltar al contenido principal
No service after battery change
Hi,
The battery of my iphone 5 died once, I changed it without issue.
It has died once again and I ordered a new battery... I checked the SKU nr and it is exactly the same model as the one which was working.
After change it shows "No service" and doesnt ask to unlock the SIM.
I decided to put back the old battery which was nearly dead... got the service back...
One friend had an original battery to borrow me. I made the test and no service again with this original battery.
I tried again the new battery, no service.
I only have network connectivity when I plug the nearly dead battery.
I've connected to Wifi to be sure to get the correct date and time.
I've doubled checked every transistors on the main board, nothing is damaged.
The 3g antenna is clean and correctly plugged....
I don't really know what to do now, any advice ?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Well this is a weird one I have never heard of this happening to a iPhone before maybe someone will no the answer
Fue útil esta respuesta?
Puntuación 1
1 comentario:
I finally found the issue.
My memory was full, and the iphone was unable to record the change of battery.
When I cleaned up the memory, the new battery was well recognised and network came back :)
- de
Fixed mine, just switched on airplane mode and switched it back on, and almost instantly it changed from searching , to my network provider!
hope this helps
Puntuación 0
Check date/time to be correct. Set auttomatically Date/time after you connect your phone to wifi if not you have to do it manually.
Puntuación 0
Añadir tu respuesta
Vincent T estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,539
