Saltar al contenido principal
Guias de reparacion para varias marcas de computadoras laptops de PC.
Preguntas 10206 Ver todo
How to remove stuck SD card out of laptop's card reader?
Hi everyone!
A while ago I inserted the dummy card in my laptop's card reader slot, but it got stuck. Any ideas how to get it out the slot, so I am able to use the slot?
Thanks!
Andrew
Update
I have tried it several times, but I am not able to get the needle to the end, because there is not enough space. Even with a second pin I am not able to get it out of the cardreader. On the other side are the contact pins and my needle gets stuck there.
Should I use a hobbytool to drill the dummy to pieces? I am affraid that's the best option...
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
Kits de Reparación de Batería de iPhone
Sólo $29.99
Buy Now
Sólo $29.99
Buy Now
5 Respuestas
Solución Elegida
Get a fine sewing pin and put a little hook on the end (about 2mm hook) get the hook in behind the card and gently tug. You may have to use a second pin without hook to guide the card up or down.
Fue útil esta respuesta?
Calificación 2
Comentarios:
I used sewing needle to pry it out--picking at it from the front on the sides and bottom. (It's made of soft plastic and I don't mind if I damage it.) Eventually it came out. YEA!
por
Thank you! Thank you! Thank you! Thank you!
por
I uses a very thin sharp knife slid it in the top of the card. Then I wiggled it from side to side. The right side then came out a little more eventuall wiggling it side to side and the left side released. I put it back in and had same problem so I threw the card out and new one worked fine. I believe it was catching on sides not top or bottom.
por
take some tweezers and pull it out of the card reader thats how I got mine out
Calificación 1
Comentarios:
It didn't work!
por
Just damaged the SD card
por
A thin pointed knife and 1 chopstick on each side - ejected in less than 30 seconds.
Calificación 0
Get some pliers and pull it out.
Calificación 0
I got a small piece of packing tape (other tape would probably also work) and inserted it next to my SD card. I kind of pressed it a bit against the SD card and was able to pull it out.
Calificación 0
Añadir tu respuesta
Z3pcs estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 18
Últimos 7 Días: 109
Últimos 30 Días: 459
Todo El Tiempo: 26,873
