Saltar al contenido principal
Micromax Canvas 2 Plus A110Q is a dual-sim Android smartphone by Micromax Mobile launched in May 2013.
Preguntas 13 Ver todo
Does not charge if kept on?
My Micromax Canvas 110Q is just 7 month old and now it does not charge when phone is ON. After switching OFF the phone it will charge, but someties it shows low battery after full charging. Restarting again will show battery as 100%. I had installed DU Battery saver app from the start. Can it be the software problem and should I uninstall the DU app?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 13
8 comentarios
how did u fix it. same problem for me also
- de
Above same problem here , my phone is micromax a110 canvas 2, it is purchased in 2013, charging problem when mobile is switch on but start to charge when it kept off.
please send me the sollution. Service center in Sangli (Maharashtra) also unable to solve my problem.
Please help.
Santosh Waghmare
7875969379
- de
I am also struggling with same problem with Micromax Canvas A110. It charged only in switch off mode. If anyone got solution to this problem, please share
- de
I have a same problem like above with my Huawei G mini which I used for last 1.5 years. Now it does not charge when phone is on but it charged if the phone is off. please help me with this issue.
- de
Mostrar 3 comentarios más
Agregar un comentario
11 Respuestas
Respuesta Más Útil
1. Download and install MTK engineering app from play store
2. Open it
3. Go to Hardware testing
4. Go to USB
5. Go to USB IF Test
6. In the first four options...do start and stop
7. Now go back and press on UART/USB switch
8. Here choose UART radio button
Now count 1....2....3....4....5... And your phone will be charging now
Fue útil esta respuesta?
Puntuación 15
21 comentarios:
You are Awsmmm Bro.
You just made my day ....:)
Thanks a lot this F**nin works (y)
- de
It worked for me in Micromax canvas spark 2
- de
It works TY Dude . and can you tell us how you got this idea ??
- de
Thanks lot.. It is works.. Very nice..
- de
Thank you bhaai its working..,Now just only one problem how to install new apps every time it showing error that insufficient storage.
- de
Mostrar 16 comentarios más
That would be my first guess, try uninstalling and let us know what happens.
Puntuación 0
1 comentario:
Did you see what happens when you disconnect the battery from the logic board and then reattach it?
- de
same problem here , i have not installed any saver app but facing the same problem.Mobile is charging in switch off mode only, what can be the reason please tell ASAP ?
Puntuación 0
same case with me on unite2 plz help;no batterysaver app or anything! hope it works after somet ime!
Puntuación 0
hi guys,
my micromax a110Q , 1year old.
Started hanging & auto on off.
After restoring factory set up & updating soft ware . its dead.
No charging, totally black screen.
can some body suggest a way out.
Puntuación 0
1 comentario:
I have installed in Canvas 2.2 and battery is not charging as usual, if you remove battery and put. Is it necessary to update mtk engineering tool ?
- de
Please help.
Santosh Waghmare
7875969379
Puntuación 0
2 comentarios:
the same problem with me i could not charge my micromax a110q when is on and if i switch off my mobile and plug in for charge it become charge. please send your answer on my e-mail: suryapurbia1@rediffmail.com
- de
Same problem with my micromax A110 from last 2 days. i also purchased in 2013. plz mail me solution on nchitikant@gmail.com
- de
This was firmware bug lately patch by micromax in new updates. Check new updates from micromax if updates not available then try to flash custom firmware but you have to root it before going further.
Puntuación 0
1 comentario:
Smith Can you tell me how to flash frimware and root micromax a110 phone I have the same problem of not charging when power is on.
- de
Puntuación 0
1. uninstall DU battery first.it sucks out your battery more.
2. Check out the charging port ..it may be filled with dust and lint...try cleaning it with a safety pin
[ NOTE: be careful not to damage the port ].
3. Now try restartin it.
Puntuación 0
Go to a Mobile Mechanic do not Spoil ur time here....
Puntuación 0
Hi, have you performed a battery recalibration? To be honest no one battery apps are good, they just cancel some logs from your device (in few words) Here is how to perform a battery recalibration.
How to calibrate a smartphone battery: Let the device reach 0% and let it shut down till you can not even turn it on
Connect the battery rechargerwall and let the device reach 100% battery without turn it on.
Once the device reached the 100% battery let it connected for other 2 hours (without turn it on)
Once the 2 hours are passed with the rechargerwall battery connected to the electricy, turn on your device for 20 min, after that turn it off.
Once you turned off the device disconnect the rechargerwall from the wall then disconnect the usb data cable from rechargerwall battery. After that reconnect the usb data cable to the rechargerwall battery and then reconnect the rechargerwall battery to the wall electricity
This operation should be repeated for 3 days in a row. Do not perform this operation more than 3 times in 2 months.
Let me know
Puntuación 0
1 comentario:
I have micromax canvas tab which now a days becing a problem it doesnt charge properly
If it is charged it goes complete dead
I hv to connect the charger nd then use
If i am onning also the flash comes later within a seconds it goes off y it is so and any suggestion for it
- de
Añadir tu respuesta
Sudipta Ray estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 14,239
