El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3634 Ver todo
Touch ID not working after LCD replace
Hi,
I have 5s that screen already replaced with the new one, and now the touch id is not working.
sorry the operation was not successful touch id
after i restore, touch id menu is gone from Settings.
but, the one thing i know is. when i bought this phone from the previous owner, the lcd has already replaced too not from Apple, but the touch id is working.
so might be there's another way to fix it.
so confusing me because the previous owner of this phone is missing, i cant contact them.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
the touch id still original.
por
Agregar un comentario
3 Respuestas
Respuesta Más Útil
if you haven't already tried, do a soft reset by holding the home button and the power/lock button until the phone turns off.
Fue útil esta respuesta?
Calificación 1
Comentarios:
Soft reset worked for me.
Tks alot!
Mat
por
Worked for me too. I switched on the phone with out connecting the home button after connecting it touch id did not work. But then i saw your post and did a soft reset all good nowww!!!!!
por
Nothing to do with original owner or a replacement screen..
Make sure you have seeded the little touch id connector correctly again if it is then you have cause damaged to it when removing from old screen
Calificación 0
Comentarios:
I mean is,
If the replacement LCD is causes touch id not working, so why the previous owner can use it, whereas he already replace it too.
because i have research, that is because LCD Replacement. my home button working properly, but not with the touch id.
por
Did you yourself actually see this touch ID work, or did the seller just say it worked?
A new lcd shouldn't effect the touch ID, either the little snap connection is not fully seated, there's some lint/fibers in the connection to stop contacts fully touching. Or the cable has been damaged.
Calificación 0
Comentarios:
yes, i actually use and see the touch id worked for a couple week before i do a replacement LCD.
por
Añadir tu respuesta
Alvin Giovanno estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 7
Últimos 30 Días: 32
Todo El Tiempo: 14,158
