Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
Preguntas 18 Ver todo
Baxi Luna3 boiler runs out of hot water?
Afternoon, I have a Baxi Luna 3 Comfort Combi Unit, The boiler goes on when I open faucets or showers, But goes cold in about 5 minutes tops, Then takes forever to heat up again. Cant even take showers. The unit is 2 years old, I checked the heat exchanger and flushed it out just incase of scaling or slime. Some dirt but nothing to stop water flow. This has been a constant issue. Was a direct replacement with an old baxi unit due to hurricane sandy.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits para Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Respuesta
Solución Elegida
Have you reviewed this Troubleshooting guide from the manufacture? Luna 3 Comfort Troubleshooting Guide.
You also may want to look at the water pressure of your water line feed and the baseboard loop. If the loop looses pressure it will shutdown the boiler.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Justin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 48
Todo El Tiempo: 3,695
