Saltar al contenido principal
Modelo A1224 / mediados de 2007 y principios de 2008/2, 2,4, o 2,66 GHz Procesador Core 2 Duo
Preguntas 549 Ver todo
Fuzzy display on startup - iMac 20" early 2009
During installation of a new superdrive, I unplugged the 4 inverter cables from the display, once all put back together and on startup I get a fuzzy screen (like bad terrestrial tv signal). Once the mac has started up i can put it to sleep then wake again and the screen is back to normal. Could this be the inverter? why is it ok after sleep?
Thanks
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
sorted it know - just reset PRAM
Fue útil esta respuesta?
Puntuación 3
3 comentarios:
wow! i tried so many things, booted up to an external monitor and no graphic card issue, replaced the display cable, replaced the display and nothing worked.
read this and reset the pram and voila!
thanks robert.
- de
Amazing solution, thank you Robert , i owe you a drink!
- de
I have been booting up then putting computer asleep for about 5 years as work around. I decided to search for solution and this did solve my issue. I myself did not have a mac keyboard, for PC keyboard to reset PRAM is Windows key + ALT + P + R when powering up, wait until you hear the second chime at bootup.
- de
Añadir tu respuesta
robert kebell estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 352
