Saltar al contenido principal
Modelo A1278 / 2.26 o 2.53 GHz Procesador Core 2 Duo EMC 2326 de mediados de 2009
Preguntas 744 Ver todo
2,5" harddisk adapter for 160 GB Toshiba harddrive?
Hi,
My 13" MacBook Pro crashed in a water damage, but the harddrive is still intact, my problem is; getting the data out.
I found the tutorial of replacing the harddrive, but I don't have a new one to replace it in. I already had an 2,5" adapter, but it doesn't fit.
Can anyone tell me which adapter I need to use?
Some more information on the haddrive:
Toshiba, Diske Drive MK1655GSXF
HDD2H75
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Here's the adapter I use on a daily basis (in English): http://eshop.macsales.com/item/Newer%20T...
Fue útil esta respuesta?
Puntuación 4
2 comentarios:
Use one of those myself. + Ralph Also mayer I like your new avatar in Meta.
- de
+ I like Swiss Army Knives. I have to get one of these adapters.
- de
You can use an universal SATA/IDE -> USB adapter like this one. I use them all the time. Better than a swiss knife ;-)
Puntuación 1
4 comentarios:
Could you please link to the english version of that link as well? I'm curious to read about the device. Thanks!
- de
Mayer provided it - thanks +
- de
+ for the lead, he can read about mine in English but can he order on in Denmark?
- de
He should be able to. Amazon ships worldwide.
- de
You can use this Firewire enclosure
Oh and to clarify one the type of cable that's necessary, it's possible that you have an ATA cable, the drive is SATA.
Puntuación 0
5 comentarios:
Okay. I'm form Denmark so it is too exspensive to buy on this site. But any kind SATA External Enclosure will fit it?
- de
Yes, any enclosure for a 2.5 in. SATA drive will work. I suggest, that unlike what others are recommending, you make sure it has firewire, as it is significantly faster than USB.
- de
Unless you are referring to firewire 800 USB 2 is about the same speed and about half the cost and many times more flexible. I used one of these 2 days ago to make a copy of my main drive using CCC and the process was flawless and the cloned drive funtions perfectly. Ralph
- de
Yeah I'm referring to 800, wayy faster.
Of course when USB 3.0 comes out...
- de
Thank you very much. Amazon ships wordwide, but it is 50% on top of the price.
I just need to get all my files out, I have plenty of disk space other places. So I'll go for at cheap one with USB. But thank you very much for the advises.
- de
Añadir tu respuesta
Jesper estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,002
