Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
The first iteration of Studio Beats headphones were manufactured by Monster in 2008. They are available in a large variety of colors. Screwdrivers, plastic opening tools, and possibly a soldering kit may be required for repair of this device.
Preguntas 43 Ver todo
Audio Cable is Broken!
My audio cable is not working. What should I do in order to fix the cable?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
Where is is broken? At the ends by the connector?
- Por
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Clay Jacobs, you could replace the 3.5mm audio jacks on either side, if you know how to solder. The soldering is identical to this repair . Easiest would be to get a replacement cable, should be about ~$5-$10. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 1
It depends on what problem you are having with the audio cable.
You can check the following troubleshooting guide (Troubleshooting Beats Studio First Generation) to help diagnose the problem.
If all else fails, the guide recommended by oldturkey03 should be great for soldering on new jacks. If the in-line buttons are the problem, it would probably be easier to buy a new cable.
Puntuación 1
Añadir tu respuesta
Clay Jacobs estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 665
