The Dell Inspiron 1500 is available with a range of Intel processors (from the 1.86GHz Celeron M M540 up to the T7500 2.2GHz Core 2 Duo).
Preguntas 20 Ver todo
What is the procedure for replacing my Dell laptop's keyboard?
My daughter's Dell laptop keyboard has failed.
Can I repair or replace it, or must the keyboard be repaired or replaced by a qualified technician? If I can replace it following a procedure, where might I find the procedure?
I don't see Dell keyboard replacement procedures in iFixit.com.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
4 Respuestas
Solución Elegida
Check these two links:
http://support.dell.com/support/edocs/sy...
http://support.dell.com/support/edocs/sy... (This is the manual, the guide with pictures starts on page 109).
This info should be enough for you to be able to do it yourself. Also, it would be great if you could create a repair guide for iFixit for doing this. It'd be a great help to people later on who want to be able to do this
Fue útil esta respuesta?
Calificación 2
Comentarios:
Research + Ralph
por
check out this site: http://support.dell.com/support/edocs/sy...
Calificación 0
Comentarios:
rab has already listed that site.
por
you can visit '''Dell Technical Support''' to resolve your issue. you will get a manual guide here from which you can easily learn about replacing dell laptop’s keyboard.
Calificación 0
I’ll recommend you something which will provide you the solution of this problem. Contact to [http:// https://www.lenovosupportphonenumber.com...|Lenovo Customer Service.]
Calificación 0
Añadir tu respuesta
LeRoy Younglove estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 15
Todo El Tiempo: 4,892
