Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
Preguntas 608 Ver todo
How can the fans be disassembled without damage?
I have a fan that's very audibly grumbling while at idle speeds. I've opened the case and cleaned the fan blades and casings, with no result. I suspect there's dust/dirt in the actual bearings inside of the fan.
I've attempted to gently (but very forcefully) pry the fan piece with the blades away from its axle, to no avail. I fear that using more force would break it, but I can't tell how it's connected to know for sure.
I'd really like to fix this problem without dropping $50 on a replacement fan, if all I need is a cleaning.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Sadly, these fan units are not really designed to be taken apart. While its fun to do on a junker, if you want to reuse it it just won't do. Best to replace.
Fue útil esta respuesta?
Puntuación 2
take some compressed air and some elektronic cleaner.
wd40 could also work. cheaper and easier is to buy a new fan.
Puntuación 0
Comentarios:
Fairly confident on how to clean it -- it's how to get the pieces of the fan to physically separate that I'm having a hard time with :). I feel like if I pry against the rotor any harder, something's going to snap.
- Por
First I won't use any oil (including WD40) as it will attract dust which will clog the bearing and the blades.
- Por
Añadir tu respuesta
Tom Frost estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 70
