Also known as Samsung Galaxy Note 4G, Samsung SGH-I717, Samsung Galaxy Note LTE released in January of 2012.
Preguntas 44 Ver todo
Phone power off alone,and vibrate.
My phone come on for a few min. then power off alone or the option to power off my phone pops up on the screen. when phone power my phone continue to short vibrate. What could be wrong or what should I do?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 13
Comentarios:
My phone Micromax canvas colours 2 is switched off and is vibrating continuously. I have kept it near a bottle in the storage of my scooter. What to do ? It's screen is also coming white from sides.
por
Agregar un comentario
9 Respuestas
Solución Elegida
remove and reinset the battery, press the volume up key, home button and power button simultaneously. you can see recovery console. format the cache partition and select reboot. fault may solve. Note: dont format the flash because your all data will be lost
Fue útil esta respuesta?
Calificación 12
Comentarios:
If my Phone haven't removable battery and Power button not worked .. then what can I do
por
Rohit, this is about Galaxy note. if you have any trouble with your phone you can ask a question mentioning the model info. we can help you to fix the phone !
por
I got LG G3 my phone suddenly restart.. with viberation
por
Jennetta Davis, start by replacing the battery. This will also provide you with a known-good starting point for further trouble shooting. For now, it does sound like a battery issue.
Calificación 2
It's not the battery it's the power button:
http://www.blogtechtips.com/2014/04/06/s...
Calificación 2
Comentarios:
Pls have not satisfied with galaxy note issue my own keep on restarting over and over till it will drains up the battery i'm tired.
por
yes, your galaxy note 3 may have a battery issue
____________________________________________________
achat galaxy s5
Calificación 0
Samsung galaxy s4
Sometimes all at once the phone will start to vibrate and won't stop , likes it's stuck on vibrate. only way to stop it is to turn it off . Any advice
Thank you !!!!
Calificación 0
Comentarios:
i would like to know the answer to this as well
por
I have same problum
I press the volume dowen(volume up key is not working) key, home button and power button simultaneously but odin mod appeair thair is downleoding......
Donot trun off target!!
What can i do
Calificación 0
Comentarios:
I have the same issue with j5.but when I plug charger it continues to vibrat but doesn't on...
por
dont press vol down....press vol up instead
por
i have samsung galaxy note edge.. its working properly but when i switch it off, this phones starts vibrating continuasly , and i cant switch it on with power button, i need to connect to charger then it will be on... what is the probelum in phone , kindly reply
Calificación 0
Comentarios:
My Galaxy Note 4 suddenly went off while charging on 40%. The screen then displays the charge symbol with no battery indicating that the battery is zero but then it tries booting itself which then vibrates, goes off and shows empty battery level. I thought it was a battery issue so I replaced the battery and it still does the same. It won't boot. keeps indicating empty battery though on other Note 4, my battery shows 100% charged. I can't even enter hard reset mode with the keys because you try and the phone goes off and restarts. No physical damages or what so ever. Only a month old.
por
my s7 edge phone is vibrating automatically after every hours at 45 mins.I did stop all notifications for apps and stopped vibrate options of phone setting too..still its vibratiing.so now what I should do??
Calificación 0
mine was doing the same thing, changed batteryy and it worked
Calificación 0
Añadir tu respuesta
Jennetta Davis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 25
Últimos 7 Días: 233
Últimos 30 Días: 911
Todo El Tiempo: 53,916
