Are there diagnostic LED'S on EMC 2114?
Does anyone have a picture & description of the diagnostic LED's ( if they exist) in imac intel model 2114?
Es esta una buena pregunta?
G A long, just to augment mayer's answer"To Access the LEDs:
Follow the take apart instructions to remove the RAM access door, front bezel, and lower
EMI shield.
Locate the SO-DIMM slot and LVDS video connector. The three troubleshooting LEDs 1, 2, and 3 are located to the right of the LVDS cable connector, under a square of black tape. Peel back the tape to view the LEDs. Note that the LEDs are marked 1, 2, 3 from left to right, as show below. An additional front LED is located in an opening at the center of the right speaker, as shown below.
LED #1
Indicates that the trickle voltage from the power supply has been detected by the main
logic board. This LED will remain ON whenever the iMac (Mid 2006 17-inch) is connected to a working AC power source. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power source is disconnected or the power supply is faulty.
LED #2
Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED #3
Indicates that the computer and the LCD display are communicating. This LED will be ON when the computer is turned on and video signal is being generated.
Front LED
Indicates that the computer has power but no video signal (e.g., the computer is starting up or the display has entered Sleep mode, turning off the video signal). This LED will pulse when the entire system has entered Energy Saver mode.
Fue útil esta respuesta?
They're to the right of the RAM slots, usually covered up by a piece of black tape.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 270
