Saltar al contenido principal
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
Preguntas 56 Ver todo
Phone fell, no visible damage, doesn't turn on
My 920 fell onto a hard floor. There is absolutely no visible damage, and absolutely no sign of life. Something disconnected? Component destroyed?
If I can get it apart, is there any possible solution that I - not particularly gifted in these areas, but not stupid - can effect myself?
Es esta una buena pregunta?
Puntuación 7
10 comentarios
I have a Nokia Lumia 928 and I had dropped it that last time when I was moving to My new apt and it fell and u went almost 2-3 months without a phone and I finally got one n I need help to make it come back on this is really a small phone please help
. ~THANKS ~XOXOXO
- de
hey that just happened to me i just threw the phone against the wall and it turned right back on. weird but it works.
- de
Please read the comment below, don't throw your phone.
- de
Please dont throw the phone... Just press the power and volume low key simultaneously for 30 secs...phone will definitely reboot...
- de
Ok you have to on the button on your phone
- de
Mostrar 5 comentarios más
Agregar un comentario
4 Respuestas
Solución Elegida
kLyon, if you are absolutely sure that it is not coming on, you may need to take a look at the inside of it. Pay close attention to your battery contacts. Use this video guide to work on your phone. Of course, try a reset as explained on here and some more on here first. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 3
3 comentarios:
Thanks for your help! I found a comment on a forum about someone in the exact same situation as me - dropped phone, no visible damage, bricked. Even though nothing happened when it was plugged into power, he - as a last resort - put the phone on a wireless charger. In ten minutes it was fine.
So I tried the same thing: same result. Ten minutes and it was fine, back to normal.
Odd, huh?
- de
I need help for my infinix hot note, it fell on hard ground and is not displaying any context
- de
my itel A11 fell down on the rog and my flashlight was on when it fell but when i wanted to on my phone it did not on so i decided to remove the battery after removing the phone begin to vibrate so i removed the battery again after that it did not on again...pls what can i do
- de
Respuesta Más Útil
Press the power key and the down volume key simultaneously for 30 seconds. Its a hard powerboot and it turns on the phone. Just happened to me today and I remember doing it anytime my phone freezes.
Good luck,
FABJ.
Puntuación 7
5 comentarios:
I am so very happy, my phone rebooted with this fix. So wonderful to have it working.
- de
Thanks alot man, much appreciated. worked for me. Thanks again
- de
Great Help Man. It worked for me.
- de
Thanks man it worked
- de
Does the phone have to be plugged to a charger
- de
It is possible the LCD is damaged. Replacing the glass, digitizer and LCD as one complete unit ran me about $80. If you have ever worked on cell phones and have the proper tools, you can do it.
Puntuación 1
4 comentarios:
The screen seems fine (visually). The phone just won't power up. If the screen was damaged, wouldn't the phone power up and just not display anything?
- de
The phone could be powering up, but it is possible you can't tell because the LCD may be messed up.
- de
Same here - if I charge, the display works fine to show me tha manufacturer and the % of battery, then dies again. The power button itself seems not working after fell. (Prestigio)
- de
thank you so much !!! it worked for my phone.
- de
my phone fell and refuse to on whats the problem
Puntuación 0
Añadir tu respuesta
kLyon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 18
Ultimos 30 días: 56
Todo El Tiempo: 36,314
